ion_cortex
1 year agoArria 10 GX dev kit-CvP Functionality
Hi everyone, I’m running into a problem with my Arria 10 GX development kit and hoping someone here can help. I’m trying to get the Configuration via Protocol(CvP) working within the PCIe Hard IP. I...
JohnT_Altera
1 year agoHi,
If you are programming the jic file then you should be programming the flash that is connected to the Arria 10 FPGA and not the Max 5 device. Can you check if your MSEL setting on your board is set to Active Serial?
You may refer to https://www.intel.com/content/www/us/en/docs/programmable/683227/current/default-switch-and-jumper-settings.html SW4 setting. You will need to set it to 010 as mention in Table 6.
The default setting is Passive Serial.
