Beginner_in_FPGA's avatar
Beginner_in_FPGA
1 year ago
N6000-PL MAX10 Build
I am currently building the N6000 MAX10 BMC provided in this guide, when running the script as mentioned in the guide "./build.sh" the script throws errors. I am not able to clear this error and the file is not present in the directory. Any ideas as what to do next is deeply appreciated?
Thank you,
Best Regards.
  • KianHinT_altera's avatar
    KianHinT_altera
    1 year ago
    I had a discussion with one of our OFS-BMC team on the build issue and the srec_cat command and they are aware of the issue and due to release a new build script enhancement to resolve it.
    Issue cause : new Quartus version added additional padding zeroes in .hex file compared to the older versions.
    As the new build script is undergoing corporate release process, we could try this first by manually changing the ./build.sh script first to solve the padding issue on the hex file.
    Change the command from this :
    elf2hex -v bmc_bootloader.elf 0x00000000 0x0001ffff --width=32 --record=4 --little-endian-mem --no-zero-fill --create-lanes=0 bmc_bootloader.hex
    To this in build.sh:
    elf2hex -v bmc_bootloader.elf 0x00000000 0x0001ffff --width=8 --little-endian-mem --no-zero-fill --create-lanes=0 mem_init/max10_onchip_flash.hex
    I haven't confirmed on the fix yet as I'm still currently building it on BMC v14 although they mentioned the new script is targeted for BMC v15 (max10_bmc_v3_15_0). Will let you know the result later as it will take take some time to build
    Kian
