N6000-PL MAX10 Build
- 2 years ago
I had a discussion with one of our OFS-BMC team on the build issue and the srec_cat command and they are aware of the issue and due to release a new build script enhancement to resolve it.
Issue cause : new Quartus version added additional padding zeroes in .hex file compared to the older versions.
As the new build script is undergoing corporate release process, we could try this first by manually changing the ./build.sh script first to solve the padding issue on the hex file.
Change the command from this :
elf2hex -v bmc_bootloader.elf 0x00000000 0x0001ffff --width=32 --record=4 --little-endian-mem --no-zero-fill --create-lanes=0 bmc_bootloader.hex
To this in build.sh:
elf2hex -v bmc_bootloader.elf 0x00000000 0x0001ffff --width=8 --little-endian-mem --no-zero-fill --create-lanes=0 mem_init/max10_onchip_flash.hex
I haven't confirmed on the fix yet as I'm still currently building it on BMC v14 although they mentioned the new script is targeted for BMC v15 (max10_bmc_v3_15_0). Will let you know the result later as it will take take some time to build
Kian
Is there anything else that you want to clarify related to this case, otherwise I would like to close the case and transition this thread to community support.
Kian
