N6000-PL MAX10 Build
- 2 years ago
I had a discussion with one of our OFS-BMC team on the build issue and the srec_cat command and they are aware of the issue and due to release a new build script enhancement to resolve it.
Issue cause : new Quartus version added additional padding zeroes in .hex file compared to the older versions.
As the new build script is undergoing corporate release process, we could try this first by manually changing the ./build.sh script first to solve the padding issue on the hex file.
Change the command from this :
elf2hex -v bmc_bootloader.elf 0x00000000 0x0001ffff --width=32 --record=4 --little-endian-mem --no-zero-fill --create-lanes=0 bmc_bootloader.hex
To this in build.sh:
elf2hex -v bmc_bootloader.elf 0x00000000 0x0001ffff --width=8 --little-endian-mem --no-zero-fill --create-lanes=0 mem_init/max10_onchip_flash.hex
I haven't confirmed on the fix yet as I'm still currently building it on BMC v14 although they mentioned the new script is targeted for BMC v15 (max10_bmc_v3_15_0). Will let you know the result later as it will take take some time to build
Kian
Sorry for the late response, I was attempting to build the BMC and also got the same error as yours.
May I know what version of BMC you're building , the github branch ( mine is max10_bmc_v3_14_0) . Wondering whether is there any error on this branch as there is newer branch in github.
I will also check whether is there any case log in the system for BMC generation.
Kian
