AN 754: MIPI D-PHY Solution with Cyclone V - questions on VCCIO/VCCDP/VREF connection
I am referring to the AN 754 (MIPI D-PHY Solution with Passive Resistor Networks in Intel® Low-Cost FPGAs) to acheive MIPI receive in Cyclone IV.
We can see in the document at Table 1, in FPGA I/O buffer mode for RX, that :
- For high-speed signaling mode, we can use differential I/O standard (LVDS25)
- For low-power signaling mode, we can use single-ended mode with HSTL12 or LVCMOS12 I/O standard
I would like your approval, for FPGA I/O buffer in RX mode only and for low-power signaling only, that we can use HSTL12 single-ended mode with the following connections for the same IO bank:
1) VCCIO=2.5V
2) VCCPD=2.5V
3) VREF=0.6V
4) and that there is no need for any VTT connection at all
I will be grateful if there is someone that can give me an approval on the connections detailed in items 1/2/3/4.
Thanks in advance.
Hi Aqid,
The AN754 refers to the Cyclone® IV, Cyclone V, Intel® Cyclone 10 LP, Intel MAX® 10.
But sorry for the typo, I am referring specicially to the Cyclone V.
Thanks for the approval, so it should be okay to connect with the requirement in 1/2/3:
1) VCCIO=2.5V
2) VCCPD=2.5V
3) VREF=0.6V
Regarding the VTT, I will follow the AN754 at Figure 1 (FPGA Unidirectional Receiver Implementation Block Diagram) or at Figure 3 (FPGA As Receiver HS-RX and LP-RX Modes IBIS Simulation Circuit) that is not using VTT at all.
THANKS A LOT FOR THE SUPPORT - I appreaciate a lot!!!
David R.
- DdRd
I will appreciate a lot if you can update me that anyone is working on my question...
- AqidAyman_Altera
You wanted to connect HSTL-12 with the 1/2/3/4 requirement.
May I reconfirm with you with my understanding?
Aqid
- DdRd
Hi Aqid,
Yes, I confirm but HSTL-12 is in RX mode only.
David R.
- AqidAyman_Altera
Hello David,
Referring to Cyclone IV datasheet for HSTL-12 I/O standard, I afraid some of the requirements are not meeting the specification.
HSTL-12 need a typical 1.2V VCCIO and need VTT. Refer here:
Aqid
- DdRd
Hi Aqid,
I would like you to double check because of the followings:
A) Per Intel document AN 754 (MIPI D-PHY Solution with Cyclone V), at Figure 3, there is no need for VTT.
B) Per same document AN 754, at Table 1, for FPGA I/O RX mode , for Low-power signaling mode and for HTSL-12 I/O standard, I/O voltage Supply is defined as 2.5V.
More than this, there is two notes (1) + (2) in the same table:
(1) The LVDS can co-exist in the same I/O bank as HSTL-12 when the FPGA is configured as input buffer in Cyclone® V devices.
(2) Input buffer for LVDS and HSTL-12 I/O standards are powered by VCCPD in Cyclone® V devices.
C) Also per Intel document CV-5V2 (Cyclone 5 Device Handbook), at Table 5-9, we can see that for 1.2V HSTL, VCCIO needed for input is VCCPD when VCCPD=2.5V
More than this, there is a note (11) in the same table:
(11) Input buffers for the SSTL, HSTL, Differential SSTL, Differential HSTL, LVDS, RSDS, Mini-LVDS, LVPECL,
HSUL, and Differential HSUL are powered by VCCPDThanks in advance.
David R. - AqidAyman_Altera
Hello David,
Are you referring to Cyclone IV or Cyclone V? In your early description it mentioned on Cyclone IV. I really apologies if I understand it wrongly.
As if for Cyclone V, as your findings and pointing out the document, it should be okay to connect with the requirement in 1/2/3.
However, for the VTT, based on the CV-5V2 (Cyclone 5 Device Handbook), at Table 5-9, it should have connection to VTT=0.6V.
As for the Figure 3 you showed in AN754, it mentioned Cyclone IV.
- DdRd
Hi Aqid,
1) VCCIO=2.5V
2) VCCPD=2.5V
3) VREF=0.6V
Hello David,
Thanks for the clarification.
I am happy to help you!
I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
