installation & licensing
516 TopicsSW Download from the website not working
Hello, When I try to download any software on the website, it gives me a form to fill out my personal information. It pulls it from my profile except for the industry. I fill that and hit continue. But then no software download begins or provides a link. It takes me back to the form. I have tried multiple browsers and OS and even tried with my personal computer. But it behaves the same way. Please help. Currently, we are not able to benefit from our paid subscription. Thank you. Best regards,234Views0likes3CommentsQuartusIQ VS Code extension: `@QuartusIQ` fails when asked to run `ls`
Environment: QuartusIQ VS Code extension `altera.quartus-pilot-vscode` 0.10.8 VS Code on Linux Model: Gemini 4 Hydrogen Steps to reproduce: Open a folder in VS Code and start a new chat. Send `@QuartusIQ hi`. It responds correctly. Send `@QuartusIQ run "ls" command in my current directory`. The request fails with the error below. Expected: QuartusIQ lists the files in the current directory, using the `ls` tool listed in the user guide. Logs: 2026-11-25 15:23:51.864 [info] Activating build c933603-559 (3c2f087) 2026-10-16T07:56:01Z 2026-11-25 15:23:51.864 [info] Telemetry reporter initialised 2026-11-25 15:23:51.864 [info] Trace export enabled (otel=https://qiq-otel-prd.altera.com/api/public/otel environment=prod) 2026-11-25 15:23:51.864 [info] Apply handler and diff provider registered 2026-11-25 15:23:51.864 [info] Copilot compatibility probe command registered 2026-11-25 15:23:51.864 [info] [Checkpoints] LangGraph database: /home/abdulraouf/.config/Code/User/workspaceStorage/3620cb3f350c61db81e64397aa0c599a/Altera.quartus-pilot-vscode/langgraph-checkpoints/checkpoints.sqlite 2026-11-25 15:23:51.864 [info] [Filesystem] Workspace root: /home/abdulraouf/Downloads 2026-11-25 15:23:51.864 [info] [MCP] starting child process: /snap/code/281/usr/share/code/code 2026-11-25 15:23:51.864 [info] Chat participant registered 2026-11-25 15:23:51.864 [info] [MCP] {"timestamp":"2026-11-25T10:23:50.842Z","event":"programmer_start","level":"INFO","logger":"ProgrammerRuntime","tool":"server","phase":"start","msg":"server","session_id":"ccf6a57bcfeb","pid":343221,"audit_log":null,"audit_log_env":"QUARTUS_AUDIT_LOG_FILE"} 2026-11-25 15:23:51.864 [info] [MCP] {"level":30,"time":"2026-11-25T10:23:51.004Z","event":"mcp.tools.registered","changed":true,"added":["search_altera_docs","search_quartus_msgs","search_ip_knowledge_graph","search_community_docs","lookup_drc_rules","search_reference_designs","get_quartus_report_index_status","get_quartus_signoff_verdict","get_quartus_report_sections","read_quartus_report_sections","get_related_report_context","get_quartus_timing_issue_context","analyze_bitstream","generate_programming_file","generate_helper_image","generate_rsu_jic","check_pr_compatibility","compare_files","analyze_flash_compatibility","read_jtag_config","read_config_status","program_sram_device","program_flash_device","check_qspi_flash","read_qspi_manufacturer_id"],"removed":[],"updated":[],"total":25,"inventory":{"search":["search_altera_docs","search_quartus_msgs","search_ip_knowledge_graph","search_community_docs","lookup_drc_rules","search_reference_designs"],"host":["get_quartus_report_index_status","get_quartus_signoff_verdict","get_quartus_report_sections","read_quartus_report_sections","get_related_report_context","get_quartus_timing_issue_context","analyze_bitstream","generate_programming_file","generate_helper_image","generate_rsu_jic","check_pr_compatibility","compare_files","analyze_flash_compatibility","read_jtag_config","read_config_status","program_sram_device","program_flash_device","check_qspi_flash","read_qspi_manufacturer_id"]},"msg":"MCP tool inventory registered"} 2026-11-25 15:23:51.864 [info] [MCP] QuartusIQ MCP Server running on stdio... 2026-11-25 15:23:51.864 [info] [MCP] {"level":30,"time":"2026-11-25T10:23:51.005Z","event":"mcp.server.started","msg":"QuartusIQ MCP Server running on Stdio"} 2026-11-25 15:23:51.864 [info] [MCP] connected (pid=343221) 2026-11-25 15:23:56.916 [info] [MCP] {"level":30,"time":"2026-11-25T10:23:56.915Z","dbPath":"/home/abdulraouf/Downloads/.quartus/report-index/reports.sqlite","msg":"Quartus report index refreshed"} 2026-11-25 15:24:00.058 [info] [chat] Progress UI: stable (chatParticipantAdditions unavailable; use Extension Development Host, VS Code Insiders, or enable-proposed-api for Altera.quartus-pilot-vscode) 2026-11-25 15:24:00.058 [info] [Model] name="Gemini 4 Hydrogen" id="models/gemini-4-hydrogen" vendor="gemini" family="models/gemini-4-hydrogen" version="1.0.0" maxInputTokens=983040 2026-11-25 15:24:00.058 [info] [Filesystem] Approval store loaded: /home/abdulraouf/.config/Code/User/workspaceStorage/3620cb3f350c61db81e64397aa0c599a/Altera.quartus-pilot-vscode/filesystem-approvals.json 2026-11-25 15:24:00.088 [info] [MCP] Resolved 25 tools: search_altera_docs, search_quartus_msgs, search_ip_knowledge_graph, search_community_docs, lookup_drc_rules, search_reference_designs, get_quartus_report_index_status, get_quartus_signoff_verdict, get_quartus_report_sections, read_quartus_report_sections, get_related_report_context, get_quartus_timing_issue_context, analyze_bitstream, generate_programming_file, generate_helper_image, generate_rsu_jic, check_pr_compatibility, compare_files, analyze_flash_compatibility, read_jtag_config, read_config_status, program_sram_device, program_flash_device, check_qspi_flash, read_qspi_manufacturer_id 2026-11-25 15:24:00.088 [info] [HITL] Tool approval enabled for: program_sram_device, program_flash_device, check_qspi_flash, write_file, edit_file, request_external_source_access, update_approval_policy 2026-11-25 15:24:00.192 [info] [Langfuse] CallbackHandler constructed sessionId=626c4d17-4600-4490-be93-e19519734b71 tags=vscode,real 2026-11-25 15:24:00.390 [info] [Context] window=983040 tools=0 reserve=2048 usable=980992 trigger=735744 keep=98099 2026-11-25 15:24:00.434 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task. 2026-11-25 15:24:03.889 [info] [stream] Complete. main agent chunks: 1, subagent chunks: 0 2026-11-25 15:24:46.815 [info] [chat] Progress UI: stable (chatParticipantAdditions unavailable; use Extension Development Host, VS Code Insiders, or enable-proposed-api for Altera.quartus-pilot-vscode) 2026-11-25 15:24:46.816 [info] [Model] name="Gemini 4 Hydrogen" id="models/gemini-4-hydrogen" vendor="gemini" family="models/gemini-4-hydrogen" version="1.0.0" maxInputTokens=983040 2026-11-25 15:24:46.816 [info] [Langfuse] CallbackHandler constructed sessionId=626c4d17-4600-4490-be93-e19519734b71 tags=vscode,real 2026-11-25 15:24:46.929 [info] [Context] window=983040 tools=19317 reserve=2048 usable=961675 trigger=721256 keep=96167 2026-11-25 15:24:46.961 [warning] [Tools] Description exceeds 2048 characters for: generate_rsu_jic, write_todos, task. 2026-11-25 15:24:49.810 [error] Chat participant error: VS Code language model response stream failed: {"error":{"message":"{\n \"error\": {\n \"code\": 503,\n \"message\": \"This model is currently experiencing high demand. Spikes in demand are usually temporary. Please try again later.\",\n \"status\": \"UNAVAILABLE\"\n }\n}\n","code":503,"status":"Service Unavailable"}}29Views0likes3CommentsQuartus Prime Lite 25.1 Windows complete download blocked by Akamai HTTP 403
Hello Altera Support, The official Quartus Prime Lite 25.1 Windows download page lists Quartus-lite-25.1std.0.1129-windows.tar (6.5 GB), SHA-1: 812e29e9d16f0359ed27d2eb5a16c42f6701cde5. After signing in and accepting the download agreement, the website redirects to: https://download.altera.com/akdlm/software/acdsinst/25.1std/1129/ib_tar/Quartus-lite-25.1std.0.1129-windows.tar The file endpoint consistently returns HTTP 403 Forbidden with Server: AkamaiGHost and an Access Denied response. aria2 1.37.0 returns error 22 and receives zero file bytes. A normal single-connection GET also fails. Browser User-Agent and official-site Referer headers do not resolve the problem. Public DNS resolution was checked; using a current CDN address while retaining the original TLS hostname also returns HTTP 403. Test date: November 17, 2026. Akamai reference: 18.cc20c817.1794907231.3f0b1df7 Earlier reference: 18.c4f50f17.1794905230.d2fb33b4 Please investigate the denial rule using these reference IDs and provide a working official download URL for the complete Windows package. Please also confirm whether any additional authorization is required for a standard download client. Thank you.55Views0likes2CommentsQuesta-ModelSim UI scaling problems in Linux
Hello Has anybody been able to solve the issue of UI of Questa not scaling correctly on linux with wayland? I am using Ubuntu 26.04 with wayland and UI is just tiny, icons, are so small i cannot read any text. When opening a new project, file explorer is also tiny. Fonts i could change in the config file but icons, menus and everything else is just extremely small. Problem is even worse on high resolution displays. Regards, Haris963Views0likes15CommentsProblems with registered computers in SSLC
Hello, I recently logged in to the Altera SSLC to renew a license. I used to have multiple host computers registered, which now seem to be missing: (None appear either when opening the "View All Computers" window) So I tried to re-create the computer that is to host said license, and I came upon the following error: It would seem that the computer both exists and does not exist! For the sake of seriousness and good taste, I will abstain from making any jokes about Schrödinger and quantum superposition. In any case, I see some maintenance is going on today, so that might be related to the issue. Otherwise, I would greatly appreciate if this could be looked into. Thank you and regards, Noah106Views0likes3CommentsSW-QUESTA generates unusable license files
Hello, I generated three free SW-QUESTA licenses through SSLC: LR-206587, LR-206591 and LR-206592. The downloaded files contain no active FEATURE/INCREMENT lines. Questa Altera Starter FPGA Edition 2025.2 reports: “Unable to checkout a license.” The NIC Host ID matches the registered computer. SALT_LICENSE_SERVER points directly to the downloaded file. Repeated license generation has not resolved the issue. Could you check my entitlement and provide a valid license file? I can provide the files privately.84Views0likes3CommentsDownload Center profile registration fails: System unavailable
Hello, I am trying to download Quartus Prime Lite 25.1 for Windows for university coursework. I can sign in to MyAltera successfully. When I complete the required Download Center profile form and continue, it repeatedly displays: 'System unavailable. Please try again later.' I retried in Google Chrome and cannot reach the installer download. Is there a known issue with profile registration, or an official way to complete registration and obtain qinst-lite-windows-25.1std-1129.exe? Thank you.315Views0likes4Comments
