Knowledge Base Article
Why is there an "unrecognized device" error when using quartus_jli to configure or program a JAM file for flash devices of 2 GB or larger?
Description
In any versions of Altera® Quartus® Prime Pro Edition Software, the quartus_jli command may report an “unrecognized device” error when a JAM file targets a flash device that is 2 GB or larger. This behavior is specific to JAM files used with large flash devices and does not occur with smaller flash sizes.
Resolution
Use the following workaround to avoid the error:
  1. Run the
    jtagconfig
    command to detect the connected JTAG hardware.
  2. After the hardware is detected, run
    quartus_jli
    to configure or program the JAM file.
There is currently no plan to fix this behavior in a future Quartus® Prime release.
Updated 5 months ago
Version 3.0
