Knowledge Base Article
Why does the Timing Analyzer report an unconstrained clock on the internal state signal when using the Generic Serial Flash Interface IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1.1 and earlier, you might see that the Timing Analyzer report an unconstrained clock on the internal state signal below, when using the Generic Serial Flash Interface (GSFI) IP.
<instance_path>|intel_generic_serial_flash_interface_top_0|serial_flash_inf_cmd_gen_inst|state[0]
Adding a create_generated_clock constraint removes the unconstrained clock report but introduces setup timing violations because the clock relationship is inferred as zero, making timing closure unachievable in Quartus® Prime Pro Edition Software version 25.1.1.
Resolution
  • There is no reliable SDC-based workaround to achieves timing closure; adding create_generated_clock can lead to setup violations due to a zero clock relationship.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 25.3.
Updated 9 months ago
Version 2.0
