Knowledge Base Article
Why does the Tensor FIR IP generation fail with a missing-file error?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1, you might see an error related to a missing file when performing Tensor FIR FPGA IP generation.
Example error output
Info: tensor: "Generating: tensor_tensor_fir_100_vs35orq"
Error: add_fileset_file: No such file <user directory>/26.1/quartus/dspba/backend/include/cmd_tools/share/bp2_prog_c.h
while executing
"add_fileset_file "bp2_prog_c.h" OTHER PATH "$bepath/include/cmd_tools/share/bp2_prog_c.h""
(procedure "gen_files" line 327)
invoked from within
"gen_files $entity "VHDL""
(procedure "gen_sim_vhdl_files" line 2)
invoked from within
"gen_sim_vhdl_files tensor_tensor_fir_100_vs35orq"
Info: tensor: Done "tensor" with 2 modules, 25 files
Info: Finished: Create simulation model
Error: SPD file was not generated: <user directory>/tensor/tensor.spd
Error: Could not generate simulation scripts
There are three operation modes for the Tensor FIR IP:
- Memory-Mapped
- non-Memory-Mapped
- Auto-Programming
The missing -file error occurs when using modes 1 and 2.
Mode 3 is not affected by the error.
Resolution
A patch is available to fix this problem in Quartus Prime Pro Edition Software version 26.1.
Download and install patch 0.01dsp below.
The error will be fixed in future versions of the Quartus Prime Pro Edition Software.
Updated 6 months ago
