Knowledge Base Article
Why does the Single Floating Point Variable Streaming Reverse FFT IP produce an incorrect output when the input order is set to Natural?
Description
Due to a problem in the Quartus® Prime Software version 25.3.1 and earlier, the "Natural" option for setting "Input Order" is incorrectly available for selection and unsupported when generating the FFT IP. This option is available when using the following parameters:
- Direction: "Reverse",
- Data Flow: "Variable Streaming",
- Representation: "Single Floating Point".
Resolution
This problem is scheduled to be fixed in release 26.1 of the Quartus® Prime Software with the removal of the unsupported “Natural” option.
Additional Information
This problem affects the FFT IP in Quartus® Prime Software versions 17.0 to 25.3.1.
Updated 7 months ago
