Knowledge Base Article
Why does the simulation of my Altera® AXI BFMs fail?
Description
In the Quartus® Prime Pro Edition Software, a VHDL testbench generated by Visual Designer Studio or Platform Designer using Altera® AXI BFM will error out. The Altera AXI BFMs only support testbenches generated in Verilog HDL or System Verilog HDL.
In the Siemens* Questa* Simulator, the error message may be similar to this:
** Error: <file name>.vhd: (vcom-1598) Library "<library name>" not found.
Resolution
To avoid this problem, generate the testbench in Verilog HDL or System Verilog HDL.
Updated 4 months ago
