Knowledge Base Article
Why does the ASMI Parallel II IP or the Generic Quad SPI Controller II IP fail to access a QSPI flash memory device?
Description
Due to a problem in multiple Quartus® Prime Pro Edition and Standard Edition software versions, the ASMI Parallel II IP or the Generic Quad SPI Controller II IP fails to access a Quad SPI flash memory device.
The affected software versions are:
  • Quartus® Prime Pro Edition software versions from 22.1 to 25.3
  • Quartus® Prime Standard Edition software versions from 22.1 to 24.1
Chronologically,
  • Prior to version 22.1, the initial state of DATA[3:2] was high.
  • For the affected software versions, the initial state of DATA[3:2] was incorrectly changed to Hi-Z.
For reader’s information, some quad SPI flash memory devices support RESET or HOLD function on DATA[3] and WRITE_PROTECT function on DATA[2]. DATA pins can be known as DATA, DQ, IO, or SIO across different QSPI flash memory device vendors.
This modification to Hi-Z is recognized as low, thus the active-low RESET, HOLD and WRITE_PROTECT functions are enabled. With these, they prevent the flash controller IP from gaining access to flash devices.
Resolution
DATA[3:2] must be kept high as the initial state.
If the targeted flash device is the Active Serial configuration flash memory, this problem is fixed starting from,
  • Quartus® Prime Pro Edition software version 25.3.1, and
  • Quartus® Prime Standard Edition software version 25.1.
Otherwise (i.e. generic-purpose flash memory or affected software version), please refer to the workarounds below.
For affected software versions,
Targeted Flash Device
Workarounds
Active Serial configuration flash memory (Case 1)
Differentiated with:
  1. DATA[3:2] pins are assigned to dedicated AS_DATA[3:2] pins
  2. Disable dedicated Active Serial interface option is turned off
  3. Enable SPI pins interface is turned off
The initial state of DATA[3:2] is Hi-Z.
Add external pull-up registers to the I/O VCC voltage on DATA[3:2].
Internal weak pull-up resistor option is unavailable for dedicated AS_DATA pins.
Active Serial configuration flash memory (Case 2)
  2. Disable dedicated Active Serial interface option is turned on
  3. Connected to a SFL IP with Share ASMI interface with your design option turned on
Generic-purpose flash memory
  1. DATA[3:2] pins are assigned to generic I/O pins
  2. Enable SPI pins interface option is turned on
  • Add external pull-up registers to the I/O VCC voltage on DATA[3:2], or
  • Enable internal weak pull-up resistor on DATA[3:2] pins in Quartus® design project
After Quartus® Prime Pro Edition software version 25.3.1 and Quartus® Prime Standard Edition software version 25.1,
Workarounds
The initial state of DATA[3:2] is reverted to high.
No workaround is needed.
Related IP Cores
ASMI Parallel II IP, Generic Quad SPI Controller II IP
Updated 4 months ago
Version 8.0
