Knowledge Base Article
Why does Nios® V processor system simulation fail with no print-out message and multiple “x” values along the processor’s signals?
Description
This problem may be seen in the Synopsys* VCS* and VCS* MX simulators when simulating the Nios® V processor system generated from
  • Quartus® Prime Pro Edition Software version 23.1 to 23.4, or
  • Quartus® Prime Standard Edition Software version 23.1std
This is due to the X-propagation support in the simulators.
Resolution
To workaround this problem, follow these steps:
Switch off the X-propagation feature on the processor core,
  1. Generate testbench system from the Platform Designer.
  2. Navigate into the Synopsys* simulator directory.
    • $ cd <Project>/sys_tb/sys_tb/sim/synopsys
  3. Append -xprop=xpropconfig into the shell script in the vcs or vcsmx folder.
For example:
  • USER_DEFINED_ELAB_OPTIONS=”-xprop=xpropconfig”
  1. Create a file named xpropconfig in the vcs or vcsmx folder (beside the shell script).
  2. Copy the following text into xpropconfig, and change the processor entity name.
tree {<Nios V processor HDL entity name>} {xpropOff};
  1. Run the simulator.
This problem is currently scheduled to be resolved in Quartus® Prime Pro Edition Software version 24.1 and later.
Updated 5 months ago
Version 6.0
