Knowledge Base Article
Why does my Frame Buffer II drop every other output sample?
Description
Due to a problem with the Frame Buffer II IP Core prior to Quartus® Prime Software version 17.0, you will see this behavior if you select the 128 bit Avalon®-MM master(s) local ports width.
Resolution
To work around this problem, select the 256 bit local ports width. Qsys® will automatically insert a width adapter if you need to connect to other 128 bit slaves.
This problem has been fixed starting in the Quartus Prime software version 17.0.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
