Knowledge Base Article
Why does a Nios® V processor with Nios V Debug IP debug session fail in Ashling* RiscFree* IDE when System Bus access is disabled?
Description
Due to a problem in the Ashling* RiscFree* IDE software version 26.3-B, a processor debug session might fail when the Nios® V Debug IP’s System Bus is disabled for designs targeting Nios V processor with Nios V Debug IP.
This is because the default GDB remote timeout in Ashling* RiscFree* IDE is insufficient to execute Abstract Access Memory thru Nios V Debug IP. The IDE is experiencing premature timeout.
Resolution
To work around this problem in the Ashling* RiscFree* IDE software version 26.3-B,
- Enable System Bus in Nios V Debug IP
- Make the necessary connections to the system peripherals.
Refer to Nios® V Embedded Processor Design Handbook - NiosV Debug IP.
This problem is currently scheduled to be resolved in a future release of the Ashling* RiscFree* IDE Software.
Updated 3 hours ago
