Knowledge Base Article
Why are my high fanout cells not duplicated?
Description
Due to an problem in the Quartus® Prime Pro Edition Software versions 24.3 and later, duplication of cells with high fanout is prevented even when duplication assignments such as DUPLICATE_REGISTER or DUPLICATE_SYNC_FANIN are defined explicitly. This behavior affects cells that have a driver in a different partition, including both signals and clocks. For example, a register in partition A that has its clock coming from the root partition will not be duplicated despite having the appropriate assignment.
Resolution
To work around this problem, remove the partitions or ensure that the affected cells are not driven by other cells in different partitions.
If removing partitions from your design is not feasible, patches are available to work around this problem. Download and unzip the zip file that matches your Quartus® Prime Pro version and operating system from this KDB.
Quartus® Prime Pro Edition Version |
Patch number |
24.3 |
[0.36|^quartus-24.3-0.36.zip] |
24.3.1 |
[1.30|^quartus-24.3.1-1.30.zip] |
25.1 |
[0.38|^quartus-25.1-0.38.zip] |
25.1.1 |
[1.29|^quartus-25.1.1-1.29.zip] |
25.3 |
[0.28|^quartus-25.3-0.28.zip] |
25.3.1 |
[1.07|^quartus-25.3.1-1.07.zip] |
Patches for versions 25.3 and 25.3.1 also address additional problems; refer to the README files for more information.
This problem is fixed beginning with the Quartus® Prime pro Edition Software version 26.1.
