Knowledge Base Article
What is the latest device firmware for the Quartus® Prime Pro Edition Software version 25.3?
Description
The latest device firmware for Quartus® Prime Pro Edition Software version 25.3 is available for download below.
Fixes for the following problems are included in the latest release (The newest release contains all prior fixes and supersedes earlier device firmware releases).
Change Log
Firmware version 0.23fw:
Agilex® 7 FPGA I-Series catastrophic trip (nCATTRIP) signal asserts at a temperature lower than the pre-configured threshold setting. Fixed the firmware flow during channel switching causing nCATTRIP to assert earlier than expected.
Firmware version 0.03fw:
Fixed race condition in handling SHA isr and resumption of FPGA data blocks. Drain DMA post a configuration/PR to flush out left over data if any.
Resolution
Download the latest device firmware below.
Note:
- Patches must be applied to the Quartus® Prime Pro Edition Software and the Quartus® Prime Pro Edition Software Programmer and Tools.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run the programming file generation or conversion using the Quartus® Prime Software programming file generator.
