Knowledge Base Article
How do I enable polarity inversion on a per lane basis in the JESD204B Intel® FPGA IP?
Description
When using the Avalon® memory mapped register interface in the JESD204B Intel® FPGA IP, you can enable polarity inversion through bit[0] of lane_ctrl_<n> registers (0x4 - 0x20), where <n> represents the targeted lane number.
Refer to the following links for JESD204B address map and register definitions:
- TX: https://www.intel.com/content/www/us/en/programmable/support/literature/ug/altera_jesd204_tx_regmap.html
- RX: https://www.intel.com/content/www/us/en/programmable/support/literature/ug/altera_jesd204_rx_regmap.html
- For designs that do not use the register interface, follow the instructions in the workaround under the Resolution section, to enable polarity inversion on a per lane basis in the JESD204B Intel® FPGA IP.
Resolution
If the JESD204B Intel® FPGA IP core register access is unavailable, perform the following workaround sequence to turn on polarity inversion:
- Change directory into <IP core name>/altera_jesd204_phy_<acds_version>/<sim or synth>/
- Open the file <IP core name>_altera_jesd204_phy_<acds_version>_<random_string>.v with any text editor.
- Look for port .csr_lane_polarity in the inst_<tx and/or rx>_mlpcs instantiation.
- The width of the input port csr_lane_polarity is L, where L represents the total number of lanes in the JESD204B Intel® FPGA IP core. The LSB represents lane 0, the least significant 1 bit represents lane 1,..., MSB represents lane L-1.
- To enable polarity inversion, drive 1 to the targeted bit in the csr_lane_polarity input port.
The following example shows an 8-lane design, with polarity inverted for lane 0 to lane 2:
module <name>_altera_jesd204_phy_<acds_version>_<random_string> #(
altera_jesd204_tx_mlpcs #(
) inst_tx_mlpcs (
.csr_lane_polarity (7'b0000_0111), // TX: polarity inverted for lanes 0-2
altera_jesd204_rx_mlpcs #(
) inst_rx_mlpcs (
.csr_lane_polarity (7'b0000_0111), // RX: polarity inverted for lanes 0-2
