Knowledge Base Article
Error(24244): Found an error when generating the IBIS Output File for board analysis. Refer to "<project_directory>/output_files/xxx.log" for more information
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3 and earlier, you mat see this error when using the EDA Netlist Writer to generate an IBIS Model. This problem occurs when the project includes R-tile or P-tile I/O pins.
Resolution
This problem has been fixed beginning with version 24.3 of the Quartus® Prime Pro Edition Software.
Updated 1 month ago
