Knowledge Base Article
Error(24244): Found an error when generating the IBIS Output File for board analysis
Description
Due to a problem is Quartus® Prime Pro Edition Software version 25.3, you might see this error when generating this IBIS files. This problem only occurs on Windows* OS.
This problem occurs because the quartus_py.exe file has changed location in the installation directory but the IBIS writer still calls the file from the previous location.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 3 months ago
Version 5.0
