Knowledge Base Article
Error(23098): One or more blocks are configured incorrectly and will not have the desired functionality. --BCM instance name: pio_1_2
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, you might see the error above when using the I/O PLL Parameterizable Macro (ipm_iopll).
The error only occurs when using non-integer values for the VCO Clocks and Output Clocks in the I/O PLL Parameterizable Macro.
Resolution
To work around this problem, use non‑integer values for the VCO Clocks and Output Clocks in the IOPLL IP.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 5 months ago
Version 3.0No CommentsBe the first to comment
