Knowledge Base Article
Error: Unknown option: -port_type while execute set_instance_assignment with the option
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3 and 25.1.1, you might see this error when running a "set_instance_assignment" with -port_type option e.g.
Error:Unknown option: -port_type
Error:---------------------------------------------------------------------------
Error:Usage: set_instance_assignment [-h] [-help] [-long_help] [-comment <comment>] [-disable] [-entity <entity_name>] [-fall] [-from <source>] -name <name> [-remove] [-rise] [-section_id <section id>] [-tag <data>] [-to <destination>] [<value>]
Error: -h: Quick usage
Error: -help: Short help
Error: -long_help: Long help with examples and possible return values
Error: -comment <comment>: Comment
Error: -disable: Option to disable assignment
Error: -entity <entity_name>: Entity to which to add assignment
Error: -fall: Option applies to falling edge
Error: -from <source>: Source of assignment
Error: -name <name>: Assignment name
Error: -remove: Option to remove assignment
Error: -rise: Option applies to rising edge
Error: -section_id <section id>: Section id
Error: -tag <data>: Option to tag data to this assignment
Error: -to <destination>: Destination of assignment
Error: <value>: Assignment value
Error: while executing
Error:"set_instance_assignment -name DUPLICATE_SYNC_FANIN …"
Resolution
A patch is available to fix this problem in the Quartus Prime Pro Edition Software version 25.3. Download and install patch 0.24 below.
A patch is available to fix this problem in the Quartus Prime Pro Edition Software version 25.1.1. Download and install patch 1.49 below.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 3 months ago
Version 8.0No CommentsBe the first to comment
