Knowledge Base Article
Error: Tcl error: DVR_API: List of error MSGs are {list element in braces followed by "]" instead of space
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1, you might see this error when compiling your design in Design Space Explorer II.
Error: Tcl error: DVR_API: List of error MSGs are {list element in braces followed by "]" instead of space (Command was: lmap panel_name [::qed_lib::rdb_util::get_report_panel_names_matching -panel_name {} -string_match {Synthesis||Logic Synthesis Stage||Partition*||*Optimization Results||Multiplier Implementations||Multiplier Implementation Report} -regexp_match {}] {::qed_lib::rdb_util::get_report_panel_str -panel_name $panel_name})}
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 25.3.1, download and install patch 1.21
This problem is fixed beginning with version 26.1 of the Quartus® Prime Pro Edition Software.
Updated 4 months ago
Version 7.0No CommentsBe the first to comment
