Knowledge Base Article
Error: No spd files are included in quartus project
Description
In the Intel® Quartus® Prime Standard Edition Software version 17.1, the error message above may be seen while executing the ip-setup-simulation script on a project targeting a device that doesn't belong to the Intel® Arria® 10, Intel® Stratix® 10, or Intel® Cyclone® 10 families.
The ip-setup-simulation script requires an Intel® Arria® 10, Intel® Stratix® 10, or Intel® Cyclone® 10 Platform Designer folder structure to work properly.
Resolution
To work around this problem, switch from using the ip-setup-simulation script to the ip-make-simscript script.
For more information on the ip-make-simscript script usage, please consult the Intel® Quartus® Prime Standard Edition Handbook Volume 1 Design and Synthesis, page 255.
Updated 11 months ago
Version 3.0
