Knowledge Base Article
Error: niosv_g_dcache.sv: part-select direction is opposite from prefix index direction
Description
Due to a problem in the:
- Quartus® Prime Pro Edition Software versions 24.3.1, 25.1, and 25.1.1, and
- Quartus® Prime Standard Edition Software version 24.1.
When the Nios® V/g processor is configured with No Data Cache and enabled with Error Detection and ECC Status Reporting, performing Analysis and Synthesis fails with the error "niosv_g_dcache.sv: part-select direction is opposite from prefix index direction".
Note that this issue has no relationship with No Instruction Cache.
Figure. Nios® V/g Processor Setting to Replicate the Error
Resolution
To work around this error,
- Select 1Kbytes Data Cache.
- Apply a Peripheral Region that covers the whole Nios® V processor’s data_manager address map
- Enable Error Detection and ECC Status Reporting.
By implementing Peripheral Region, the above settings can emulate an ECC-enabled Nios® V processor system that operates without caches.
Figure. Workaround (in this example, the whole Nios® V processor’s data_manager address map is 1GB)
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3 and Quartus® Prime Standard Edition software version 25.1.
