Knowledge Base Article
Error: invalid command name "else"
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1 and earlier, you might see the error messages below when generating a VHDL simulation model in Platform Designer that includes the Remote Update IP.
Info: while executing
Info: "else {
Info: do_vhdl_sim_cbx altera_remote_update_core
Info: }"
Info: (procedure "do_vhdl_sim" line 8)
Info: invoked from within
Info: "do_vhdl_sim altera_remote_update_core"
Error: Generation stopped, 1 or more modules remaining
Resolution
To work around this problem, generate Verilog Simulation Model for Remote Update IP.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 26.1.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
