Knowledge Base Article
Error: Execution of command "{/nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 19.1 Windows* version onwards, you might see this error when generating the UniPHY-based External Memory Interface IP.
Resolution
Install the Windows Subsystem for Linux (WSL) on Windows OS for all Quartus® Prime Standard Edition Software versions 19.1 Windows version onwards. For more details, refer to this article.
There is an additional workaround requirement if you are using Quartus® Prime Standard Edition software version 19.1 on Windows. For more details, refer to this article.
There is an additional workaround if you use Windows 10 version 19.03 and later. For more details, refer to this article.
Related Articles
- How to install the Windows Subsystem for Linux (WSL) on Windows OS?
- FATAL: Cannot generate IP in a Windows environment!
- Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Updated 10 months ago
Version 3.0No CommentsBe the first to comment
