Will failure analysis be provided for a field returned part which was manufactured in 2013? Please advise. Thank you
- Zawani_M_Intel
Hi LLow0,
You may let us know which device it is. We can check if it is supported.
Thanks!
Wani
- LLow0
Hi Wani,
It is a IOFPGA part. Its part number is EP4CGX50DF27C8N (CPN: 16-4288-01). Photo has been attached. Than you
Lay Foon
- Zawani_M_Intel
Hi Lay Foon,
It is supported device.
Let's tell me a story of this fails unit :
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Did they violate solder re-flow temperature profiles, moisture sensitivity? Please provide the re-flow temperature profiles.
6. Did you swap the failure device to a known good board? Is the failure following the device or board?
7. Is this a prototype build or volume/mass production?
8. Kindly provide quantitative investigation result that could proof the failure is Intel FPGA induced.
Wani
- LLow0
Hi Wani,
Kindly refer to the feedback below:
Customer reported that copper SFP was inserted in the device. it seems to be a hardware failure and no information can be retrieved.device is hard down. By further test the customer board and confirm the board failed to boot up and failed Diagnostic test. We suspected on IOFPGA U45 since there is no progress of POSTCODE led after TTL_RESET_L is high. We measured voltage and clock supplied to IOFPGA U45, all good. We also measure impedance for IOFPGA_CPU_PCIE signals compared with KGB no abnormality. Perform X-ray on IOFPGA U45 and there is no abnormality on solderability. Perform replacement on IOFPGA U45 and perform online test also offline diag test, the result is passed. Through isolation steps, the root cause is fixed to IOFPGA U45.
Failed found once try to boot up the board. Suspected on IOFPGA U45 since there is no progress of POSTCODE led after TTL_RESET_L is high
Kindly refer to the answer from question (1)
Yes. It work before failure.
No. This part did not undergo any reflow process before this.
No. However, we will swap the failure device on another good board to confirm its failure first if ALTERA is willing to the support the FA for this part.
Volume/mass production. However, it is a field returned part from our end customer.
By replace this part with another good part, the board can function well now and work normally.
Lay Foon
- LLow0
Hi Wani,
Please advise whether ALTERA is still willing support the FA for this part. If yes, we will re-mount this part on another board and re-test it to confirm its failure before send the part to you for further FA. Thank you.
Lay Foon
- LLow0
Hi Wani,
Please advise. Thank you.
LayFoon
- LLow0
Hi Wani,
Please kindly confirm with us soonest so that we can decide the next action for this part later. Thank you..
Lay Foon
- LLow0
Hi Wani,
We are still waiting for your respond. Please quick advise whether Altera is still wiling to support the FA for this part. Thank you
Lay Foon
- Zawani_M_Intel
Hi Lay Foon,
Yes, we are happy to support for this return.
If you wish to continue with ERMA, please do let us know so we can work with more details on your issue.
Thanks!
Wani
- LLow0
Hi Wani,
Thank you to confirm it. We will re-test this part on another board first and will share the result to you after it is completed. Will keep you posted. Thank you.
Lay Foon
