LLow0
6 years agoWill failure analysis be provided for a field returned part which was manufactured in 2013? Please advise. Thank you
Zawani_M_Intel
6 years agoHi Lay Foon,
It is supported device.
Let's tell me a story of this fails unit :
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Did they violate solder re-flow temperature profiles, moisture sensitivity? Please provide the re-flow temperature profiles.
6. Did you swap the failure device to a known good board? Is the failure following the device or board?
7. Is this a prototype build or volume/mass production?
8. Kindly provide quantitative investigation result that could proof the failure is Intel FPGA induced.
Wani
