Why Generic Component are included in my GHRD?
Hi, Altera
I am a Dist. FAE in Uniquest Korea.
When building the Agilex 5 GHRD on a Linux OS, as you can see, the IPs are recognized as generic components. It would be great if an upgrade could fix this, but all the connections disappear and the design gets completely messed up. How do AEs deal with this goddamn situation? If the GHRD acts like this, there is no point for customers to use it as a reference design. Does anyone know a solution?
I've tried copying the folders and creating new components, but I'm still just getting a bunch of red errors. Please let me know a solution.Are there any issues with the portability of Quartus designs?Sorry for bad languages.Thanks.
Hudson
- HectorC_Altera
Hi Hudson,
In the past, whenever I ran into that issue (component footprint mismatch detected), running 'Sync System Info' helped me to recover the component.
Could you give it a try and see if it works for you?
If it doesn't help, could you share which Quartus and GHRD version are you using? Sharing the link from where you are downloading the GHRD would be helpful to reproduce the issue in my side.
Regards - ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
