torstein18's avatar
torstein18
4 months ago
Unstable fpga programming using HPS(Agilex3)
Hi
I have a problem where the fpga programming sometime fail when using the overlay method described here under "Reconfiguring Core Fabric from Linux":
https://altera-fpga.github.io/rel-25.3.1/embedded-designs/agilex-3/c-series/boot-examples/ug-linux-boot-agx3/#reconfiguring-core-fabric-from-u-boot
Here I have first two successful attempt then it fail on the third:
root@agilex3:~# rmdir /sys/kernel/config/device-tree/overlays/0 ; sleep 1 ; mkdir /sys/kernel/config/device-tree/overlays/0 ; cd /lib/firmware/ ; sleep 1; echo overlay.dtb >/sys/kernel/config/device-tree/overlays/0/path
rmdir: '/sys/kernel/config/device-tree/overlays/0': No such file or directory
[  182.671913] fpga_manager fpga0: writing overlay.rbf to Stratix10 SOC FPGA Manager
[  184.865664] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/firmware-name
[  184.876007] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/config-complete-timeout-us
root@agilex3:/lib/firmware# rmdir /sys/kernel/config/device-tree/overlays/0 ; sleep 1 ; mkdir /sys/kernel/config/device-tree/overlays/0 ; cd /lib/firmware/ ; sleep 1; echo overlay.dtb >/sys/kernel/config/device-tree/overlays/0/path
[  196.530735] fpga_manager fpga0: writing overlay.rbf to Stratix10 SOC FPGA Manager
[  198.659279] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/firmware-name
[  198.669650] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/config-complete-timeout-us
[  214.383163] fpga_manager fpga0: writing overlay.rbf to Stratix10 SOC FPGA Manager
[  217.508857] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004405 [hwprod 0x00004408, hwcons 0x00004405]
[  217.509907] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004407 [hwprod 0x00004408, hwcons 0x00004405]
U-Boot SPL 2025.10 (May 18 2026 - 08:34:29 +0000)
Reset state: Cold
MPU           800000 kHz
L4 Main       400000 kHz
L4 sys free   100000 kHz
L4 MP         200000 kHz
L4 SP         100000 kHz
SDMMC         200000 kHz
init_mem_cal: Initial DDR calibration IO96B_0 succeed
DDR: Calibration success
is_mailbox_spec_compatible: IOSSM mailbox version: 1
LPDDR4: 1792 MiB
ecc_interrupt_status: ECC error number detected on IO96B_0: 0
SDRAM-ECC: Initialized success
Does anybody know how to debug and fix this?
I'm using Quartus Prime Version 25.3.0 Build 109
Devboard: DK-A3W135BM16AEA: Agilex™ 3 FPGA and SoC C-Series Development Kit
  • Hi,
    Thanks for the detailed investigation, the comparison between using fpga_clk_100 directly and via the PLL is very helpful.
    Based on your results, this points to a clock/reset sequencing issue during FPGA reconfiguration, rather than a problem with the Linux overlay commands themselves.
    What is happening?
    You are using HPS Boot First with runtime reconfiguration (Linux overlay). In this mode, the HPS is running while the FPGA fabric is reconfigured dynamically by the SDM. During this process, the fabric is cleared and reloaded in phases, so resources such as PLLs are reset and rebuilt and are not stable during this window.
    A key difference between your two cases:
    • fpga_clk_100 (pin clock) is a free-running board reference and remains stable across reconfiguration
    • fpga_clk_100 routed through a fabric PLL depends on fabric resources, so it is reset and relocked on each reconfiguration
    Without proper reset control, logic can start running before the device is fully in user mode, leading to intermittent illegal states.
    The downstream effects you observed (SMMU CMD_SYNC timeout, Ethernet watchdog, system reset) are consistent with the system hanging during this transition.
    Boot mode context:
    Your flow requires HPS Boot First. In this mode, the HPS boots before the FPGA core is programmed (Phase 1 vs Phase 2). Fabric-derived clocks (PLL outputs and f2s clocks) are not present at HPS boot and are recreated during Phase 2. On each reconfiguration, these clocks are reset and can glitch or stop temporarily.
    Only board-level clocks such as fpga_clk_100, HPS_OSC_CLK, and pll_ref_clk are guaranteed to remain stable across reconfiguration.
    Likely root cause ->
    The behavior strongly indicates that PLL and/or fabric logic are being released before the FPGA reaches full user mode (nINIT_DONE) during reconfiguration.
    This can lead to:
    • PLL output not yet stable or briefly glitching
    • Logic starting in an undefined state
    • AXI transactions stalling, eventually triggering system reset
    This also explains why the issue is intermittent (for example, failing on the third attempt), depending on timing alignment during reconfiguration.
    Recommended fix
    For Agilex 3 designs using runtime FPGA reconfiguration:
    • Instantiate Reset Release IP
    • Gate PLL reset and all fabric logic reset using nINIT_DONE
    • Ensure logic is released only after:
      • nINIT_DONE indicates the device is fully in user mode
      • and PLL lock is stable (do not rely on PLL locked alone)
    In practice:
    • Hold PLL in reset until nINIT_DONE is deasserted
    • Hold all fabric logic in reset until clocks are valid and stable
    Additional notes
    • The “memory leak” warnings during overlay removal are known kernel messages and are not related to the reset issue
    • In HPS Boot First with runtime reconfiguration, fabric clocks (PLL outputs, f2s clocks) are not free-running and should not be used without proper reset gating during reconfiguration
    Summary
    The issue is caused by fabric PLL and logic being released too early during SDM reconfiguration, leading to unstable clocking and intermittent system hangs. Proper nINIT_DONE-based reset gating resolves this type of issue.
    Tien Fong
  • torstein18's avatar
    torstein18
    I had a reset problem in the fpga. After I implemented what TienFang_Altera described it worked.
    • SueC_Altera's avatar
      SueC_Altera
      Thanks for sharing the solution, torstein18!
      SueC_Altera
      Hi torstein18 - that's great that it is solved! Can you possibly share the solution?
      Sue
        torstein18
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi ,
    Just to follow up as the case been idling for sometime, may I ask the status for this case?
    Kian
    torstein18
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity legacy_baseline_top is
        port (
            -- Clock and Reset
            fpga_reset_n                        : in    std_logic;
            fpga_clk_100                        : in    std_logic;
    end entity legacy_baseline_top;
    architecture rtl of legacy_baseline_top is
        -- Component declarations
        component altera_std_synchronizer is
            generic (
                depth : integer := 3
            port (
                clk     : in  std_logic;
                din     : in  std_logic;
                dout    : out std_logic
        end component;
         component qsys_top is
            port (
                clk_100_clk                           : in    std_logic                     := 'X';             -- clk
    	   clock_bridge_0_out_clk_clk            : out   std_logic;                                        -- clk
                o_pma_cu_clk_clk                      : out   std_logic_vector(0 downto 0);                     -- clk
    	    iopll_0_locked_export                 : out   std_logic;                                        -- export
                reset_bridge_0_in_reset_reset_n       : in    std_logic                     := 'X';             -- reset_n
    	    reset_bridge_pll_in_reset_reset_n     : in    std_logic                     := 'X';             -- reset_n
                ninit_done_ninit_done                 : out   std_logic;                                        -- ninit_done
                h2f_reset_reset                       : out   std_logic                                        -- reset
        end component qsys_top;
        -- Internal signals
        signal system_clk_100                      : std_logic;
        signal pll_clk_100                         : std_logic;
        signal pll_locked                          : std_logic;
        signal pll_locked_stable                   : std_logic;
        signal ninit_done                          : std_logic;
        signal combined_reset_n                    : std_logic;
        signal system_reset_n                      : std_logic;
        signal pll_reset_n                         : std_logic;
        signal pll_reset_sync_n                    : std_logic;
        signal h2f_reset                           : std_logic;
    begin
        -- Concurrent signal assignments
        combined_reset_n <= fpga_reset_n and (not h2f_reset) and (not ninit_done);
        pll_reset_n <= fpga_reset_n and (not ninit_done);
        system_clk_100   <= fpga_clk_100;
        -- Reset synchroniser
        fpga_reset_n_sync : altera_std_synchronizer
            generic map (
                depth => 3
            port map (
                clk     => system_clk_100,
                reset_n => combined_reset_n,
                din     => '1',
                dout    => system_reset_n
        pll_reset_n_sync : altera_std_synchronizer
            generic map (
                depth => 3
            port map (
                reset_n => pll_reset_n,
                din     => '1',
                dout    => pll_reset_sync_n
    pll_stable_filter : block
    	     constant CLK_FREQ_HZ  : positive := 100_000_000;
            constant STABLE_CYCLES : positive := CLK_FREQ_HZ;
            signal counter  : natural range 0 to STABLE_CYCLES := 0;
            signal stable_r : std_logic := '0';
        begin
            p_filter : process (system_clk_100, pll_reset_sync_n) is
            begin
                if pll_reset_sync_n = '0' then
                    counter  <= 0;
                    stable_r <= '0';
                elsif rising_edge(system_clk_100) then
                    if pll_locked = '0' then
                        counter  <= 0;
                        stable_r <= '0';
                    elsif counter = STABLE_CYCLES - 1 then
                        stable_r <= '1';
                    else
                        counter  <= counter + 1;
                        stable_r <= '0';
                    end if;
                end if;
            end process p_filter;
            pll_locked_stable <= stable_r;
        end block pll_stable_filter;
    soc_inst : qsys_top
        port map (
            clk_100_clk                           => system_clk_100,
            clock_bridge_0_out_clk_clk            => pll_clk_100, --clock out from pll
            reset_reset_n                         => system_reset_n,
            iopll_0_locked_export				=> pll_locked,
    	reset_bridge_pll_in_reset_reset_n     => pll_reset_n, --Reset to pll
    	reset_bridge_0_in_reset_reset_n       => pll_locked_stable, --This goes into a reset bridge in nios with deassert synced to output clock from pll
            ninit_done_ninit_done                 => ninit_done,
            h2f_reset_reset                       => h2f_reset
    Hi, thank you for answering, I have included your suggestions in my code.
    Here is the top file of my project, I have removed everything not related to clk/reset.
    Everything inside qsys including all HPS bridges is clocked from the pll_clk_100 and reset using the pll_locked_stable after it has been syncronized to pll_clk_100 so it has a syncronized deassert.
    Do you see anything wrong with it?
    How will the h2f_reset behave during a reconfiguration, do I need to include it in the reset of the pll?
    How long do I need to wait for stable locked from pll?, I currently wait 1 second
    I also wonder what will happen if I have any in flight transactions on any of the hps bridges when I start programming the FPGA, cause I use the f2sdram as a communication channel between niosV on the fpga and the HPS, do I need to shut this off manually before fpga programming or will the fpga-manager handle this automatically?
      KianHinT_altera
      As the case been idling for quite awhile and answer already provided, i will transition this case to community support.
      Regard
      Kian
    • TienFong_Altera's avatar
      TienFong_Altera
      Thanks for sharing the top-level code, the nINIT_DONE and PLL-lock gating is on the right track. A few items stand out that likely explain why it is still intermittent.
      1. Include h2f_reset in PLL reset
      You gate fabric logic with h2f_reset, but PLL reset only uses ninit_done:
      pll_reset_n <= fpga_reset_n and (not ninit_done) and (not h2f_reset);
      During reconfiguration the HPS asserts h2f_reset as part of the bridge warm-reset handshake. The PLL should also be held in reset when h2f_reset is active, so bridge clocking stops cleanly before the fabric is wiped.
      2. Avoid clocking HPS bridges from the fabric PLL
      You mentioned all HPS bridges are clocked from pll_clk_100. This is the most likely root cause of the remaining intermittent failure.
      During overlay programming the fabric PLL is destroyed and rebuilt while the HPS keeps running. nINIT_DONE gating protects logic after user mode is reached, but it cannot prevent the PLL clock from glitching or stopping during the programming window.
      Recommended split:
      fpga_clk_100 (pin clock) → HPS bridge infrastructure, reset synchronizers, handshake logic PLL outputs → application logic only (Nios, custom IP, derived clocks)
      This matches your observation that direct pin clocking is always stable.
      3. Connect h2f_reset to bridge AXI reset in Platform Designer
      Ensure h2f_reset is connected to f2sdram_axi_reset (and other bridge resets as applicable). The HPS uses this handshake to freeze/reset bridges during reconfiguration.
      4. PLL lock wait time
      1 second is very conservative. IOPLL lock is typically well below 1 ms. The filter itself is fine, but the intermittent failure is unlikely due to insufficient wait time, it is more related to bridge clocking and in-flight transactions.
      5. In-flight f2sdram transactions, manual quiesce required
      The Linux fpga-manager disables/freezes bridges before programming, but it does not stop your Nios application or HPS-side protocol.
      If either side has active f2sdram traffic when programming begins, in-flight AXI transactions can hang the system (consistent with SMMU timeout and cold reset).
      Before each overlay apply:
      • Stop HPS-side f2sdram access
      • Signal Nios to stop and idle
      • Wait until both sides confirm idle
      • Apply overlay
      • After reconfig (nINIT_DONE deasserted + PLL re-lock), restart communication
      Suggested debug steps
      • Apply the pll_reset_n fix above
      • Move bridge clocking to fpga_clk_100; keep PLL for application logic only
      • Add Signal Tap on ninit_done, h2f_reset, pll_locked, pll_clk_100 during overlay apply
      • Test reconfig loop with all f2sdram traffic stopped
      If you can confirm whether f2sdram is active during the reconfig attempts, that would help narrow this further.
      Tien Fong
    TienFong_Altera
    What is happening?
    Boot mode context:
    This can lead to:
    Recommended fix
    In practice:
    Additional notes
    Summary
    Tien Fong
    TienFong_Altera
    Thank you for reaching out and bringing this to our attention.
    We have received your inquiry and are currently reviewing the details. We will get back to you with an update as soon as possible.
    Appreciate your patience in the meantime.
    Tien Fong
    torstein18
    [   36.922294] fpga_manager fpga0: writing overlay.rbf to Stratix10 SOC FPGA Manager
    [   39.120291] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/firmware-name
    [   39.130686] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/config-complete-timeout-us
    [   45.737387] fpga_manager fpga0: writing overlay.rbf to Stratix10 SOC FPGA Manager
    [   47.872751] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/firmware-name
    [   47.886499] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /fpga-region/config-complete-timeout-us
    [   56.264190] fpga_manager fpga0: writing overlay.rbf to Stratix10 SOC FPGA Manager
    [   59.386742] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004449 [hwprod 0x0000444a, hwcons 0x00004449]
    [   60.461430] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x0000444b [hwprod 0x0000444c, hwcons 0x00004449]
    [   61.536055] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x0000444d [hwprod 0x0000444e, hwcons 0x00004449]
    [   62.610600] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x0000444f [hwprod 0x00004450, hwcons 0x00004449]
    [   63.685144] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004451 [hwprod 0x00004452, hwcons 0x00004449]
    [   64.759689] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004453 [hwprod 0x00004454, hwcons 0x00004449]
    [   64.769798] socfpga-dwmac 10830000.ethernet eth0: NETDEV WATCHDOG: CPU: 1: transmit queue 7 timed out 6452 ms
    [   65.844646] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004455 [hwprod 0x00004456, hwcons 0x00004449]
    [   66.919264] arm-smmu-v3 16000000.iommu: CMD_SYNC timeout at 0x00004457 [hwprod 0x00004458, hwcons 0x00004449]
    [   66.934688] socfpga-dwmac 10830000.ethernet eth0: Reset adapter.
    Reset state: Cold
    MPU           800000 kHz
    L4 Main       400000 kHz
    L4 MP         200000 kHz
    L4 SP         100000 kHz
    SDMMC         200000 kHz
    LPDDR4: 1792 MiB
    torstein18
    In the original design everything run on a 100 MHz clock input fpga_clk_100, when I use this the programming is stable and work every time, but I need more than one clock in my design so I connected the fpga_clk_100 to a pll and used the output clock from the pll in the design, then the programming became unstable. Does anybody understand why? The output clock from the pll is also 100MHz
