Unstable fpga programming using HPS(Agilex3)
- 5 months ago
Thanks for the detailed investigation, the comparison between using fpga_clk_100 directly and via the PLL is very helpful.
Based on your results, this points to a clock/reset sequencing issue during FPGA reconfiguration, rather than a problem with the Linux overlay commands themselves.
What is happening?
You are using HPS Boot First with runtime reconfiguration (Linux overlay). In this mode, the HPS is running while the FPGA fabric is reconfigured dynamically by the SDM. During this process, the fabric is cleared and reloaded in phases, so resources such as PLLs are reset and rebuilt and are not stable during this window.
A key difference between your two cases:
- fpga_clk_100 (pin clock) is a free-running board reference and remains stable across reconfiguration
- fpga_clk_100 routed through a fabric PLL depends on fabric resources, so it is reset and relocked on each reconfiguration
Without proper reset control, logic can start running before the device is fully in user mode, leading to intermittent illegal states.
The downstream effects you observed (SMMU CMD_SYNC timeout, Ethernet watchdog, system reset) are consistent with the system hanging during this transition.
Boot mode context:
Your flow requires HPS Boot First. In this mode, the HPS boots before the FPGA core is programmed (Phase 1 vs Phase 2). Fabric-derived clocks (PLL outputs and f2s clocks) are not present at HPS boot and are recreated during Phase 2. On each reconfiguration, these clocks are reset and can glitch or stop temporarily.
Only board-level clocks such as fpga_clk_100, HPS_OSC_CLK, and pll_ref_clk are guaranteed to remain stable across reconfiguration.
Likely root cause ->
The behavior strongly indicates that PLL and/or fabric logic are being released before the FPGA reaches full user mode (nINIT_DONE) during reconfiguration.
This can lead to:
- PLL output not yet stable or briefly glitching
- Logic starting in an undefined state
- AXI transactions stalling, eventually triggering system reset
This also explains why the issue is intermittent (for example, failing on the third attempt), depending on timing alignment during reconfiguration.
Recommended fix
For Agilex 3 designs using runtime FPGA reconfiguration:
- Instantiate Reset Release IP
- Gate PLL reset and all fabric logic reset using nINIT_DONE
- Ensure logic is released only after:
- nINIT_DONE indicates the device is fully in user mode
- and PLL lock is stable (do not rely on PLL locked alone)
In practice:
- Hold PLL in reset until nINIT_DONE is deasserted
- Hold all fabric logic in reset until clocks are valid and stable
Additional notes
- The “memory leak” warnings during overlay removal are known kernel messages and are not related to the reset issue
- In HPS Boot First with runtime reconfiguration, fabric clocks (PLL outputs, f2s clocks) are not free-running and should not be used without proper reset gating during reconfiguration
Summary
The issue is caused by fabric PLL and logic being released too early during SDM reconfiguration, leading to unstable clocking and intermittent system hangs. Proper nINIT_DONE-based reset gating resolves this type of issue.
Tien Fong
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity legacy_baseline_top is
port (
-- Clock and Reset
fpga_reset_n : in std_logic;
fpga_clk_100 : in std_logic;
end entity legacy_baseline_top;
architecture rtl of legacy_baseline_top is
-- Component declarations
component altera_std_synchronizer is
generic (
depth : integer := 3
port (
clk : in std_logic;
din : in std_logic;
dout : out std_logic
end component;
component qsys_top is
port (
clk_100_clk : in std_logic := 'X'; -- clk
clock_bridge_0_out_clk_clk : out std_logic; -- clk
o_pma_cu_clk_clk : out std_logic_vector(0 downto 0); -- clk
iopll_0_locked_export : out std_logic; -- export
reset_bridge_0_in_reset_reset_n : in std_logic := 'X'; -- reset_n
reset_bridge_pll_in_reset_reset_n : in std_logic := 'X'; -- reset_n
ninit_done_ninit_done : out std_logic; -- ninit_done
h2f_reset_reset : out std_logic -- reset
end component qsys_top;
-- Internal signals
signal system_clk_100 : std_logic;
signal pll_clk_100 : std_logic;
signal pll_locked : std_logic;
signal pll_locked_stable : std_logic;
signal ninit_done : std_logic;
signal combined_reset_n : std_logic;
signal system_reset_n : std_logic;
signal pll_reset_n : std_logic;
signal pll_reset_sync_n : std_logic;
signal h2f_reset : std_logic;
begin
-- Concurrent signal assignments
combined_reset_n <= fpga_reset_n and (not h2f_reset) and (not ninit_done);
pll_reset_n <= fpga_reset_n and (not ninit_done);
system_clk_100 <= fpga_clk_100;
-- Reset synchroniser
fpga_reset_n_sync : altera_std_synchronizer
generic map (
depth => 3
port map (
clk => system_clk_100,
reset_n => combined_reset_n,
din => '1',
dout => system_reset_n
pll_reset_n_sync : altera_std_synchronizer
generic map (
depth => 3
port map (
reset_n => pll_reset_n,
din => '1',
dout => pll_reset_sync_n
pll_stable_filter : block
constant CLK_FREQ_HZ : positive := 100_000_000;
constant STABLE_CYCLES : positive := CLK_FREQ_HZ;
signal counter : natural range 0 to STABLE_CYCLES := 0;
signal stable_r : std_logic := '0';
begin
p_filter : process (system_clk_100, pll_reset_sync_n) is
begin
if pll_reset_sync_n = '0' then
counter <= 0;
stable_r <= '0';
elsif rising_edge(system_clk_100) then
if pll_locked = '0' then
counter <= 0;
stable_r <= '0';
elsif counter = STABLE_CYCLES - 1 then
stable_r <= '1';
else
counter <= counter + 1;
stable_r <= '0';
end if;
end if;
end process p_filter;
pll_locked_stable <= stable_r;
end block pll_stable_filter;
soc_inst : qsys_top
port map (
clk_100_clk => system_clk_100,
clock_bridge_0_out_clk_clk => pll_clk_100, --clock out from pll
reset_reset_n => system_reset_n,
iopll_0_locked_export => pll_locked,
reset_bridge_pll_in_reset_reset_n => pll_reset_n, --Reset to pll
reset_bridge_0_in_reset_reset_n => pll_locked_stable, --This goes into a reset bridge in nios with deassert synced to output clock from pll
ninit_done_ninit_done => ninit_done,
h2f_reset_reset => h2f_reset
);Hi, thank you for answering, I have included your suggestions in my code.
Here is the top file of my project, I have removed everything not related to clk/reset.
Everything inside qsys including all HPS bridges is clocked from the pll_clk_100 and reset using the pll_locked_stable after it has been syncronized to pll_clk_100 so it has a syncronized deassert.
Do you see anything wrong with it?
How will the h2f_reset behave during a reconfiguration, do I need to include it in the reset of the pll?
How long do I need to wait for stable locked from pll?, I currently wait 1 second
I also wonder what will happen if I have any in flight transactions on any of the hps bridges when I start programming the FPGA, cause I use the f2sdram as a communication channel between niosV on the fpga and the HPS, do I need to shut this off manually before fpga programming or will the fpga-manager handle this automatically?
As the case been idling for quite awhile and answer already provided, i will transition this case to community support.
Regard
Kian
