miscellaneous-mice's avatar
miscellaneous-mice
11 months ago
Unique ID registers in Cyclone V
Hello everyone,
I need to uniquely identify individual devices at runtime from the HPS (ARM Cortex-A9) side.
Does the HPS side of the Cyclone V SoC have any built-in unique ID registers, such as:
- A hardware serial number
- A unique device ID
- OTP (One-Time Programmable) fuses with unique identifiers
- Any factory-programmed identification values
What I've Tried:
I've reviewed the Cyclone V documentation but haven't found clear information about unique ID registers accessible from the HPS side (unlike some other ARM SoCs that have dedicated UID registers).
However I have seen Unique ID present in the FPGA side (https://www.intel.com/content/www/us/en/docs/programmable/683336/20-3/cores-user-guide.html), but this is not useful for my use case.
Any guidance, documentation references, or code examples would be greatly appreciated!
Thanks in advance!
  • Hi,
    A number of identification mechanisms exist on Cyclone V devices, but none of them function as a dedicated, per-device hardware serial number on the HPS side in the same way some other SoCs provide. What is available depends on which part of the chip you are accessing.
    JTAG IDCODE
    Cyclone V devices include a 32-bit IEEE 1149.1 IDCODE, and the documentation lists the values for each family member. This code identifies the device type, variant, and revision, which can be useful for checking what device is present in a chain. However, the IDCODE follows a fixed format (version + part number + manufacturer), so it does not differentiate one physical device from another of the same model.
    System Manager registers
    The HPS System Manager exposes some identification fields such as silicon revision, but the available fields generally describe the device class rather than provide a unique per-unit identifier. The fields tend to be constant across all devices of the same family/stepping.
    FPGA-side Unique ID
    There is also a Unique Chip ID feature available in the FPGA fabric through specific Intel IP. This can be used to retrieve a value that is tied to the FPGA die. If HPS access is required, it can be bridged into the HPS through lightweight AXI/Avalon interfaces. Whether this meets the use-case depends on the system architecture.
    Board-level alternatives
    Some systems instead rely on identifiers stored outside the SoC—for example:
    eMMC CID registers
    QSPI/NAND flash locations provisioned during manufacturing
    External EEPROM with a programmed serial number
    These methods provide stable per-unit identification when a silicon-level ID is not exposed.
  • FvM's avatar
    FvM
    as you already stated, various ARM 9 implementations have vendor specific unique ID features. Cyclone V HPS documentation doesn't mention such a feature. As you can access unique ID IP in FPGA fabric with a bit of platform designer programming, I don't expect a second access path through HPS register.
    I guess your use case wants to avoid loading a FPGA configuration before accessing unique ID? You may also check if the flash memory of your design provides an unique ID.
  • JitLoonL_Altera's avatar
    JitLoonL_Altera
    JTAG IDCODE
    FPGA-side Unique ID
    eMMC CID registers
  • Thanks for the response. Yes, my use case avoids loading the FPGA ID, because I need to retrieve the FPGA ID before the uboot loads the FPGA image from flash into SRAM.
    • BoonBengT_Altera's avatar
      BoonBengT_Altera
      Icon for Moderator rankModerator
      Dear miscellaneous-mice ,
      I'm glad that your doubts has been clarify. With no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
      Altera Technical Support
