Stratix 10 HPS to 25G ethernet interface
I believe Stratix 10 HPS is capable of 10/100/1000 Mb, not 10G/25G.
1.19.1. Key Features of the Intel Stratix 10 HPS • Stratix 10 TX Device Overview • Altera Documentation and Resources Center
You may have seen this already, but there's a 25G reference design, but it's connected to the fabric.
1. 25G Ethernet Intel FPGA IP Quick Start Guide • 25G Ethernet Stratix 10 Intel FPGA IP Design Example User Guide • Altera Documentation and Resources Center
- Sajeev_antony4 months ago
we plan to use the 25G Ethernet Stratix 10 IP with MAC+PCS+PMA. We are using this to conenct to a gransmaster cllock for PTP time sync. We have enabled IEEE 1588 in the IP core. also have enabled Enable 10G/25G dynamic rate switching.
We want to know,
- How to controll the switch between 10G and 25G.
- How to interface the 25G IP to the Stratix 10 HPS.
We do not need 25G throughput, just need the phyical interface for IEEE 1588 time sync messaging.
- umut_arrow3 months ago
Are you using the E-tile on Stratix 10TX or L-tile/H-tile?
If latter, please see the IP guide below for 25G ethernet below. You need the channel_reset port for dynamic switching. It shouldn't be complicated to control the ATX PLLs dynamically to switch between 10G and 25G with a reset.
In terms of interfacing it with the HPS, perhaps you can route 25G's MAC Avalon through HPS with a bridge. I've found a Stratix 10 SoC 10G 1588 PTP design example. Perhaps this design example can point you to a solution.https://www.rocketboards.org/foswiki/Projects/Stratix10SoCDesignExampleFor10GbeWithIEEE1588PTPCapability
