malcolm_locke
1 year agoSD Card Boot
Hi, I have an Agilex 5 Modular Development Board which I can boot with the supplied SD Card. I have tried to update to the latest image at Index of /2025.04/gsrd/agilex5_mk_a5e065bb32aes1_gsrd/, H...
BrianSune_Froum
Contributor
1 year agoThank you for op this ticket again.
Under investigation we found that the das-uboot 2023 had no issue while latest 2025 not even pass the spl LD compile.
Meanwhile, the A2 settings and partition for RAW is same between u-boot-socfpga 2024 and das-uboot 2023.
With on the above info altera u-boot-socfpga 2025 aligned with the latest 2025 das u-boot.
However, only u-boot-socfpga 2025 able to compiled w/o issue but unable to load the RAW partition properlly.
Please help or guide what settings are correct.
