rsu_client failing to write to slot
- 7 months ago
Dear all,
I had the same issue. Here is my solution for future reference.
I can reproduce this using the following script:
for i in {1..2000}; do
echo "Iteration $i"
rsu_client --erase 0 || break
rsu_client --add update.rpd --slot 0 || break
done
Using this script the problem occurs every 508th iteration on my system. Once in the error state, I can only get out of it by flashing the .jic file. Running the commands in U-Boot did not work for me.
In iteration 1-507 the rsu_client performs a "write" to update the CPB. In the 508th iteration it performs an additional "erase" before the "write". This is why it occurs so infrequently.
For me the fix was to increase the size of the SPT and CPB partitions to the erase size of my QSPI flash (64KiB) in the programming file generator file (.pfg).
Kind Regards,
Eric Opitz
Hi Scotty2,
Great to hear that the issue can be resolved using the Uboot user space rsu command. I not able to find similar issue related linux kernel rsu failure and I mostly use the Uboot rsu command from my experience.
I suspect probably some qspi flash operation is blocking the rsu client operation so make sure the qspi flash has been fully erased before adding the .jic file with the factory image.
Aik Eu
