glenenglish's avatar
glenenglish
1 month ago
Power management Agiilex 3/5 - Powerdown then HPS restart ?
I read in the power management section of (841346) Section 9  "Only power-off operations are supported, and they are done one time as a static option through boot mode user configuration. After po...
  • tehjingy_Altera's avatar
    tehjingy_Altera
    1 month ago
    Hi
    Your understanding is correct except for point number 2. The SDM does not get a new power configuration each time.
    The SDM will get the power configuration from the bitstream.
    The Bitstream will contain the power configuration selected base on the HPS IP settings, user are not able to change the power configuration.
