amolkumar
10 days agoFIFO trigger issue in Avalon UART IP in FPGA - CycloneV - 5CSEBA4U23C7N
Problem statement: We have created 8 Avalon UARTs in the FPGA in the above SoC. In the Quartus program the FIFO dept is set at 256(max) for each UART. The Linux HPS program is able to see the serial...
amolkumar
7 days agoaltr,16550-FIFO128 driver also does not work. Data rate is 128 bytes every 500milisecs @ 115200bps. Quartus version 24.1.
amol
tehjingy_Altera
4 days agoHi Amol
Going back to the information that you shared.
In your test you send 16 bytes and gotten 16 interrupts, could you confirm is the 16 bytes a continuous string of bytes?
The interrupt you received could be a char-timeout interrupt instead of a buffer full interrupt if the bytes are separated individual bytes.
