dpeng
10 months agoenable bridge crashes Linux
Hi, We selected a Cyclone V SoC FPGA for our project. I started on Terasic demo boards (DE0 and ADC-SoC). On these boards, that both bear a Cyclone V (P/N 5CSEMA4U23C6N), I could, with a devicetree ...
- 10 months ago
So, I think I made some progress.
- I enable the bridges in Barebox by setting the status and bridge-enable properties.
- In the Linux devicetree overlay, I only set the status property, not the bridge-enable property.
The Barebox DT (the "0x1" syntax matters, it seems):
&fpga_bridge0 { status = "okay"; bridge-enable = <0x1>; };The Linux DT overlay:
/dts-v1/; /plugin/; / { fragment@0 { target = <&base_fpga_region>; __overlay__ { #address-cells = <0x1>; #size-cells = <0x1>; // The .rbf file must be placed in /lib/firmware firmware-name = "soc_firwmare.rbf"; fpga-bridges = <&fpga_bridge0 &fpga_bridge1>; }; }; /* Enable the lightweight FPGA to HPS bridge (lwhps2fpga) */ fragment@1 { target = <&fpga_bridge0>; __overlay__ { status = "okay"; // Don't set bridge-enable! // bridge-enable = <1>; }; }; /* Enable the HPS to FPGA bridge (hps2fpga) */ fragment@2 { target = <&fpga_bridge1>; __overlay__ { status = "okay"; // Don't set bridge-enable! // bridge-enable = <1>; }; }; };Then, I when I check the status of the bridges, I get what I expect:
# for f in /proc/device-tree/soc/fpga?bridge*; do echo $(basename $f)":" $(cat $f/status); done fpga-bridge@ff600000: disabled fpga-bridge@ffc25080: disabled fpga_bridge@ff400000: okay fpga_bridge@ff500000: okay #I didn't try to communicate between the HPS and the FPGA yet, but it looks promising.
