K606
Contributor
10 months agoAgilex 5 EMAC GMII loopthrough: signals are not toggling in Fabric
I am trying to route GMII signals through the Agilex5 HPS to the Fabric. In the .dts I am using, I have the following settings for the two EMACs: &gmac0 {
status = "okay";
mac-mode = "gmii";
ph...
ShunJingG_Altera
10 months agoHello K606 ,
You may have a typo for the rx clock.
Could you please try this?
assign emac1_mac_rx_clk_wire = emac0_mac_tx_clk_o_wire; // 1GThank you.
K606
Contributor
9 months agoHi - so I changed this line. However, it seems the issue persists.
Do you know why this might be?
Please also note that the SoC system clocks are confirgured as followed:
root@localhost:~# cat /sys/kernel/debug/clk/clk_summary
enable prepare protect duty hardware
clock count count count rate accuracy phase cycle enable
qspi-clk 1 1 0 200000000 0 0 50000 Y
osc1 2 2 0 25000000 0 0 50000 Y
periph_pll 1 1 0 2500000000 0 0 50000 Y
peri_pll_c3 1 1 0 500000000 0 0 50000 Y
psi_ref_free_clk 0 0 0 500000000 0 0 50000 Y
psi_ref_clk 0 0 0 500000000 0 0 50000 Y
s2f_user1_free_clk 0 0 0 500000000 0 0 50000 Y
s2f_user1_clk 0 0 0 500000000 0 0 50000 Y
s2f_user0_free_clk 0 0 0 500000000 0 0 50000 Y
s2f_user0_clk 0 0 0 500000000 0 0 50000 Y
emaca_free_clk 3 3 0 250000000 0 0 50000 Y
emac2_clk 1 1 0 250000000 0 0 50000 Y
emac1_clk 1 1 0 250000000 0 0 50000 Y
emac0_clk 1 1 0 250000000 0 0 50000 YSo it seems the clocks are active, but when sending a 'ping' from EMAC0 to EMAC1 - there is no activity on the GMII lines in Fabric (even though it seems the ping is working in userland in the HPS)
root@localhost:~# sudo ip addr add 192.168.70.5/24 dev eth0
root@localhost:~# sudo ip addr add 192.168.70.1/24 dev eth1
root@localhost:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.70.5 netmask 255.255.255.0 broadcast 0.0.0.0
ether 3e:17:2e:db:8b:f6 txqueuelen 1000 (Ethernet)
RX packets 60 bytes 19080 (19.0 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 168 bytes 27408 (27.4 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 23
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.70.1 netmask 255.255.255.0 broadcast 0.0.0.0
ether 62:6f:4c:21:f2:f4 txqueuelen 1000 (Ethernet)
RX packets 59 bytes 18762 (18.7 KB)
TX packets 170 bytes 27588 (27.5 KB)
device interrupt 40
root@localhost:~# ping -I 192.168.70.1 192.168.70.5
PING 192.168.70.5 (192.168.70.5) from 192.168.70.1 : 56(84) bytes of data.
64 bytes from 192.168.70.5: icmp_seq=1 ttl=64 time=0.189 ms
64 bytes from 192.168.70.5: icmp_seq=2 ttl=64 time=0.034 ms
64 bytes from 192.168.70.5: icmp_seq=3 ttl=64 time=0.168 ms
64 bytes from 192.168.70.5: icmp_seq=4 ttl=64 time=0.042 ms
64 bytes from 192.168.70.5: icmp_seq=5 ttl=64 time=0.022 ms
64 bytes from 192.168.70.5: icmp_seq=6 ttl=64 time=0.009 ms
64 bytes from 192.168.70.5: icmp_seq=7 ttl=64 time=0.029 ms
64 bytes from 192.168.70.5: icmp_seq=8 ttl=64 time=0.020 ms
64 bytes from 192.168.70.5: icmp_seq=9 ttl=64 time=0.009 ms
64 bytes from 192.168.70.5: icmp_seq=10 ttl=64 time=0.034 ms
64 bytes from 192.168.70.5: icmp_seq=11 ttl=64 time=0.014 ms
64 bytes from 192.168.70.5: icmp_seq=12 ttl=64 time=0.012 ms
64 bytes from 192.168.70.5: icmp_seq=13 ttl=64 time=0.052 ms
64 bytes from 192.168.70.5: icmp_seq=14 ttl=64 time=0.025 ms
64 bytes from 192.168.70.5: icmp_seq=15 ttl=64 time=0.019 ms
^C
--- 192.168.70.5 ping statistics ---
15 packets transmitted, 15 received, 0% packet loss, time 14335ms
