IOzan
8 months agoPreloader/U-Boot Compilation Failure
General Background: I'm working with a custom board that has an Altera/Intel Cyclone V, SoC FPGA (5CSEBA6U23, similar to the DE10-Nano development kit). The board is already equipped with all the n...
IOzan
8 months agoHi, thanks again!
I added line 94 and the file started compiling—the fix definitely helped.
However, at the end of the compilation process, I received some other errors. I’ve attached the execution log.
What do you think could be the cause? Do you think the problem might be is vision and/ or licenses? if so, do you think it would help if I download an up-to-date evaluation version (30 days)? (so if it works, I will know exactly what to purchase).
Thanks a lot,
Idan
KianHinT_altera
8 months agoHi IOzan ,
In your log , seems the issue is more related to folder access permission
sed: cannot rename ./seduKkXN3: Permission denied
Did you run SoC EDS Command Shell in administrator mode?
Kian
