Power management Agiilex 3/5 - Powerdown then HPS restart ?
- 1 month ago
Hi
Your understanding is correct except for point number 2. The SDM does not get a new power configuration each time.
The SDM will get the power configuration from the bitstream.
The Bitstream will contain the power configuration selected base on the HPS IP settings, user are not able to change the power configuration.
OK thanks, so you are saying that the bitstream has to change to change the power up configuration ? That what is powered up cannot be selected by a write to some register or memory location, and trigger a reconfigure ? IE a new bitstream must be selected to boot .
I come from Xilinx MPSoC where the PMU firmware runs and can select on the fly (from mail box from the PS) or at boot.
I guess Altera saved alot fo silicon area not needing power regions like MPSoC.
This is a disappointing functionality. Agilex5 has a high static power relative to competing parts and the lack of power management features limits its use .
Still, great parts in many other ways. "You can't have everything".
Thanks for the feedback, glenenglish. I'll provide that feedback for future devices.
