glenenglish
1 month agoPower management Agiilex 3/5 - Powerdown then HPS restart ?
I read in the power management section of (841346) Section 9 "Only power-off operations are supported, and they are done one time as a static option through boot mode user configuration. After po...
glenenglish
1 month agoOK, thanks for the info..
so, back to my core question-
In HPS boot-first mode : When a power CHANGE is required in the HPS domain, can the fabric stay running (assuming that there are no outstanding HPS<> fabric DMA requests or transactions pending across the fabric<>HPS bridge ) ?
tehjingy_Altera
1 month agoHi
There is no power change ability in the HPS domain. This is done by the SDM connected to the HPS domain and it is only done on boot up.
During run time a power change could not be done.
If you mean a reset happening during run time.
Yes, the fabric is remain running during the HPS reset event.
After reset the HPS will do a reset of the fabric connected to the HPS bridges through the bridge reset signals.
