Power management Agiilex 3/5 - Powerdown then HPS restart ?
- 1 month ago
Hi
Your understanding is correct except for point number 2. The SDM does not get a new power configuration each time.
The SDM will get the power configuration from the bitstream.
The Bitstream will contain the power configuration selected base on the HPS IP settings, user are not able to change the power configuration.
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responder
Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
