Other workflow for generating Preloader since Quartus-Prime Version 19.1 with "SoC EDS 19.1 Command Shell„
I work with FPGA-Eval-Board DE10-Standard from Terasic with Cyclone V and HPS.
Before Quartus-Prime Version 19.1 workflow in "SoC EDS 18.1 Command Shell„ was:
Generate the "Preloader" using the BSP Editor
Change to Quartus Project folder:
bsp-editor.exe &
File, New ..\hps_isw_handoff\soc_system_hps_0
Generate --> ..\software\spl_bsp is generated !!
Build the "Preloader„:
Change to folder ..\software\spl_bsp
>make
--> preloader-mkpimage.bin is generated !!
SoC EDS 19.1 Command Shell„ :
bsp-editor.exe &
>make
I get the message:
"Please visit https://rocketboards.org/foswiki/Documentation/BuildingBootloader for instructions on how to build the bootloader."
But on this page I couldn't find any instuction to generate Preloader "preloader-mkpimage.bin".
Can anyone help???
Does anyone know if generation of preloader-mkpimage.bin in all future versions Quartus not exist.
Thanks for any answer.
Gerhard
- EBERLAZARE_I_Intel
Hi Gerhard,
For confirmation, are you using the Standard or Pro version of SoC EDS 19.1?
Eber.
- GQUIR2
I am using “Intel FPGA Embedded Command Shell, Version 19.1 [Build 670]” and “Quartus Prime Version 19.1.0 Build 670 09/22/2019 Standard Edition”. Best Regards Gerhard- EBERLAZARE_I_Intel
Hi Gerhard,
Regarding the preloader mkpimage bin file generation in https://rocketboards.org/foswiki/Documentation/BuildingBootloader, we are currently looking into the issue.
Will update you once the issue is fixed.
Regards.
- GQUIR2
When i follow the Steps at Documentation "Building Bootloader" at Rocketboards, i get problems when i try to make socfpga_cyclone5_defconfig !!!!
$ make socfpga_cyclone5_defconfig
HOSTCC scripts/basic/fixdep
In Datei, eingebunden von scripts/basic/fixdep.c:115:
scripts/basic/fixdep.c: In Funktion »parse_config_file«:
scripts/basic/fixdep.c:241:18: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
241 | if (!(isalnum(*q) || *q == '_'))
process_begin: CreateProcess(NULL, /usr/bin/sh ./scripts/kconfig/lxdialog/check-lxdialog.sh -ccflags, ...) failed.
process_begin: CreateProcess(NULL, /usr/bin/sh ./scripts/kconfig/check.sh cc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -ansi, ...) failed.
HOSTCC scripts/kconfig/conf.o
In Datei, eingebunden von scripts/kconfig/expr.h:15,
von scripts/kconfig/lkc.h:9,
von scripts/kconfig/conf.c:19:
scripts/kconfig/list.h:71:14: Fehler: expected »;« before »int«
71 | static inline int list_empty(const struct list_head *head)
scripts/kconfig/list.h:82:14: Fehler: expected »;« before »void«
82 | static inline void __list_add(struct list_head *_new,
scripts/kconfig/lkc.h:148:8: Fehler: unbekannter Typname: »inline«
148 | static inline tristate sym_get_tristate_value(struct symbol *sym)
scripts/kconfig/lkc.h:154:14: Fehler: expected »;« before »struct«
154 | static inline struct symbol *sym_get_choice_value(struct symbol *sym)
scripts/kconfig/lkc.h:159:14: Fehler: expected »;« before »_Bool«
159 | static inline bool sym_set_choice_value(struct symbol *ch, struct symbol *chval)
scripts/kconfig/lkc.h:179:14: Fehler: expected »;« before »_Bool«
179 | static inline bool sym_has_value(struct symbol *sym)
In Datei, eingebunden von scripts/kconfig/conf.c:7:
scripts/kconfig/conf.c: In Funktion »strip«:
scripts/kconfig/conf.c:62:18: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
62 | while ((isspace(*p)))
scripts/kconfig/conf.c:70:18: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
70 | while ((isspace(*p)))
scripts/kconfig/conf.c: In Funktion »conf_sym«:
scripts/kconfig/conf.c:173:12: Warnung: Implizite Deklaration der Funktion »sym_get_tristate_value«; meinten Sie »sym_set_tristate_value«? [-Wimplicit-function-declaration]
173 | oldval = sym_get_tristate_value(sym);
scripts/kconfig/conf.c: In Funktion »conf_choice«:
scripts/kconfig/conf.c:313:25: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
313 | else if (isdigit(line[0]))
scripts/kconfig/conf.c: In Funktion »main«:
scripts/kconfig/conf.c:568:2: Fehler: C++-Stil-Kommentare sind in ISO-C90 nicht erlaubt
568 | //zconfdump(stdout);
scripts/kconfig/conf.c:568:2: Anmerkung: (dies wird nur einmal pro Eingabedatei gemeldet)
make[1]: *** [scripts/kconfig/conf.o] Error 1
make: *** [socfpga_cyclone5_defconfig] Error 2
The whole bug report is in attachment. Has anyone an idea, what the problem is ?????
Gerhard
Hi Gerhard,
Have you downloaded and setup the toolchain?
If you have, you will still need to execute the 3 exports which is the export PATH, export CROSS_COMPILE etc.. before executing the make.
Let me know if this does not fix the issue.
- GQUIR2
I'm using "EDS Command Shell" running on Win 10 PC. How can I check if correct Toolchain is installed?
Is there manual how to install toolchain under "EDS Command Shell"?
Gerhard
Unfortunately, the building bootloader tutorial is targeting for Linux host users it is not meant for Windows 10 users.
If you opt to use Windows 10, I recommend that you use Quartus and SoC EDS 18.1 std, and use the bsp-editor flow.
If you wish to, you may install a virtual machine and learn Linux, it is pretty simple since you are going to use Linux in Cyclone V SoC anyway.
Regards.
Do you have any follow up from your side?
