GQUIR2
6 years agoOther workflow for generating Preloader since Quartus-Prime Version 19.1 with "SoC EDS 19.1 Command Shell„
I work with FPGA-Eval-Board DE10-Standard from Terasic with Cyclone V and HPS. Before Quartus-Prime Version 19.1 workflow in "SoC EDS 18.1 Command Shell„ was: Generate the "Preloader" using the BSP...
EBERLAZARE_I_Intel
6 years agoHi Gerhard,
For confirmation, are you using the Standard or Pro version of SoC EDS 19.1?
Eber.
- GQUIR26 years ago
I am using “Intel FPGA Embedded Command Shell, Version 19.1 [Build 670]” and “Quartus Prime Version 19.1.0 Build 670 09/22/2019 Standard Edition”. Best Regards Gerhard- EBERLAZARE_I_Intel6 years ago
Hi Gerhard,
Regarding the preloader mkpimage bin file generation in https://rocketboards.org/foswiki/Documentation/BuildingBootloader, we are currently looking into the issue.
Will update you once the issue is fixed.
Regards.
