GQUIR2
6 years agoOther workflow for generating Preloader since Quartus-Prime Version 19.1 with "SoC EDS 19.1 Command Shell„
I work with FPGA-Eval-Board DE10-Standard from Terasic with Cyclone V and HPS. Before Quartus-Prime Version 19.1 workflow in "SoC EDS 18.1 Command Shell„ was: Generate the "Preloader" using the BSP...
GQUIR2
6 years agoI'm using "EDS Command Shell" running on Win 10 PC. How can I check if correct Toolchain is installed?
Is there manual how to install toolchain under "EDS Command Shell"?
Gerhard
EBERLAZARE_I_Intel
6 years agoHi,
Unfortunately, the building bootloader tutorial is targeting for Linux host users it is not meant for Windows 10 users.
If you opt to use Windows 10, I recommend that you use Quartus and SoC EDS 18.1 std, and use the bsp-editor flow.
- EBERLAZARE_I_Intel6 years ago
If you wish to, you may install a virtual machine and learn Linux, it is pretty simple since you are going to use Linux in Cyclone V SoC anyway.
Regards.
