GQUIR2
6 years agoOther workflow for generating Preloader since Quartus-Prime Version 19.1 with "SoC EDS 19.1 Command Shell„
I work with FPGA-Eval-Board DE10-Standard from Terasic with Cyclone V and HPS. Before Quartus-Prime Version 19.1 workflow in "SoC EDS 18.1 Command Shell„ was: Generate the "Preloader" using the BSP...
EBERLAZARE_I_Intel
6 years agoHi Gerhard,
Have you downloaded and setup the toolchain?
If you have, you will still need to execute the 3 exports which is the export PATH, export CROSS_COMPILE etc.. before executing the make.
Let me know if this does not fix the issue.
