Linux UIO IRQ related periodic CPU usage
Thank you!
Unfortunately none of them work.
1. It is UIO irq only device, no memory region assigned to it.
2. Yes, I have done it before, it works, but I need the more stricter timing with IRQ.
3. It is an edge-triggered irq.
4. I've already tried everything (except the solution :D), nothing worked. I've made it clear/not to clear, tried with poll/select , swapped the orders etc.
Item 4: Still some question on the user application design:
Just to double confirm, WRITE() must always be after READ() and only after you are done with any data processing/event handling.
In the interrupt handler, any interrupt trigger will automatically disable the IRQ. The READ() will get a wakeup and at this point, the IRQ is disabled. The call to write() will re-enable the IRQ.
If you don't do a WRITE at all, do you see the CPU spikes? In this scenario, the IRQ should be disabled and not entertaining edge interrupt triggers. Check "cat /proc/interrupts" to see if the counts stopped.
And if you do a WRITE() from your test,
Check "cat /proc/interrupts" to see if the counts increment as expected or it storms with a huge number.
bool wait_for_irq (TX_IRQ_HANDLE_S* pHandle) { if (!pHandle || pHandle->txTrigIrqFd < 0) { std::cout << "ERROR: handle"; return false; } uint32_t info = 1; ssize_t nb = write(pHandle->txTrigIrqFd, &info, sizeof(info)); <- this re-enables IRQ, should always be only when you are ready to for the next event. if (nb != (ssize_t)sizeof(info)) { std::cout << "ERROR: writing"; return false; } nb = read(pHandle->txTrigIrqFd, &info, sizeof(info)); if (nb == (ssize_t)sizeof(info)) { return true; } return false; }
- yepp1 year ago
This was a "minimal" program for the forum, but yes, the re-enable (write) should be after the read, and also before the first read, we should enable the irq. I pasted to this minimal code appearently in the wrong order, however I tried every combination. Also with the correct READ->WRITE .
Yes, the interrupts are stopped coming when I don't re-enable it (= do not call write), but continued to waiting for it with read/poll/select. Also the /proc/interrupts counter is stopped, and the spikes in the CPU usage are gone.When I continue to re-enable the interrupts in the program, the irq counter continues from the number when it was stopped (not re-enabled).
I've already checked a few times for a storm:
- the cat /proc/interrupts shows no increment when the irq-s are not handled by the sw. (or the re-enable bit is not written back)
- I've double checked the kernel (compiled it with lots of debug messages), there is no storm for sure.
