Saijyothi's avatar
Saijyothi
10 months ago
Audio interface with Agilex 5 A5ED065BB32AI4S
Hello Team,
I need your support on interfacing an audio device with the Agilex 5 SoC FPGA and not sure the which interface i have to use in Agilex 5.
Kindly help me by sharing these details and references as well.
Thank you,
Jyothi.
  • Hi Jyothi,
    There are several different options available, but it largely depends on what board you are using. For example, if your audio output was done using USB, you could use a board similar to the Agilex 5E Premium Devkit as it has a USB interface.
    Another option is to create a peripheral in the fabric connected to the H2F bridge, and then connect that to a DAC driving a traditional audio amplifier. This would be something that you would potentially need to add to the devkit though.
    • Saijyothi's avatar
      Saijyothi
      Hello kbrunham,
      Thank you for your response.
      Here is the detailed version of my requirement:
      I am designing a custom board in which we are using Agilex5 as SoC +FPGA. In the previous revision we have used IMX8MQ and Cyclone 10, now replacing IMX8MQ & cyclone 10 with Agilex 5 SoC+FPGA.
      So i want to interface external Audio codec (SSM2518CPZ) and speaker with Agilex 5, not sure which interface i have to use in Agilex 5 to meet this requirement.
      Currently i am not using any development kit.
      Please share the interface details and reference docs for this audio requirement.
      Jyothi.
      • BoonBengT_Altera's avatar
        BoonBengT_Altera
        Icon for Moderator rankModerator
        Hi Saijyothi,
        I hope you’re doing well. I wanted to follow up and check if there are any remaining questions or concerns regarding this matter. Please let us know if anything still needs clarification — we’re happy to assist further.
        Thank you for your time, and we look forward to your feedback.
        Best Wishes
        BB
  • Hi Jyothi,
    Yes — you can use the SSM2518CPZ with an Agilex 5 SoC FPGA — but Agilex5 does not provide a dedicated I²S audio peripheral. That means you need to implement the I²S logic (soft IP) in the FPGA fabric and wire up the codec’s I²S and I²C pins to FPGA/HPS I/O.
    You can take community help or use public domain info as there’s no officially documented I²S reference design for Altera SoCFPGA.
